phaxmohdem
The next upgrade I do to my PC will be in the cooling department. (more specifically, cooling to reduce noise) (see sig for specs), and I'm looking for a few tips. It is housed in a smallish all-aluminum mid tower case, with the following air flow layout:
2x 80mm fans bottom front (intake)
1x 80mm fan rear (exhaust)
1x 80mm fan top of case (exhaust)
120mm fan in power supply helps exhaust air also.
Other fans in the system include the blower on the reference design 8800GTX, and 8600GT cards as well as a Zalman 92mm CNPS something or another on the CPU.
I'm not crazy about the Zalman's cooling performance, but it's reasonably quiet, and anything much bigger (taller) wouldn't likely fit in the case with the side panel on.
The 80mm fans are a hodgepodge collection of cheapo ball bearing fans, maybe some sleeve bearing in there too, I really don't know. I do know that the system overall is entirely too loud (sorry I don't have a dB meter to get an exact number for you) I personally believe the 80mm fans and the 8800GTX are most likely the loudest parts, and am looking for solutions to keep things both cool and quiet. What do you feel offers the best airflow for the lowest amount of noise in an 80mm fan these days? (also in an alternative GPU cooler)
