best 8 inch long gfx card
Jan 27, 2009
169
I'm wanting a gtx 970 but it's too long for my case :(
My case combined with all my hard drive bays being full can only support 8in card. Had a bigger 9600gt but had empty bays....I'm sad.. Plz help guys
Ken g6
Moderator
Dec 11, 1999
16,795
4,778
75
You can have your cake and 8 it too! ;)
Measuring merely 17cm in length, the card, specially built for small form factor PCs based on mini-ITX motherboards.
That's actually under 7 inches!
The next question is whether that's the best 8-inch-or-less card. I think I saw another 970 like this recently.
Ken g6
Moderator
Dec 11, 1999
16,795
4,778
75
GTX 970 requires either 2 6-pin connectors or 1 8-pin. They probably couldn't fit 2 6-pins on such a small card. As for the 400 Watt PSU...that's just an estimate.
Edit: I found [thread=2410573]where I'd seen[/thread] the other <7in GTX 970. ASUS might be better than Gigabyte.
Edit2: Somebody posted a picture of this dual-fan Zotac there, which PCPartPicker says is exactly 8 inches. :D
