- Aug 22, 2004
- 13,140
- 138
- 106
Thinking of buying a Thermaltake Bach case for my HTPC. It uses 60mm fans for exhaust. Can anybody tell me what the best, quiet 60mm fans are? I plan on using the ones it comes with for a while to see if they are decent, but I'd like to know what fans are better, if the stock ones suck.
The stock rear fans specs are, according to TT "Dual 60 x 60 x25 mm, 2500rpm, 19dBA". I'm guessing the airflow isn't very high on these, but we'll see.
Thanks!
Thanks!
