Best ~$300 card right now?
Barfo
27,539
212
I was thinking a 7950 would be fine given my budget, but which brand should I get if I have to buy it from Amazon, with no rebates? I heard XFX isn't top notch anymore, how's Sapphire? does ASUS still make AMD cards? Is there a comparable Nvidia card at this price range?
raghu78
4,093
1,475
the HD 7950 is the best card at USD 300 - 330. here are a few good options.
Sapphire HD 7950 boost. built on a reference HD 7970 PCB. compatible with full cover HD 7970 waterblocks. unlocked voltage. ref blower style cooler which could get a bit loud at 1150+ mhz clocks.
http://www.amazon.com/Sapphire-Displ...dp/B00BXVFM3K/
Sapphire HD 7950 boost. reference HD 7950 PCB. compatible with full cover HD 7950 waterblocks. unlocked voltage. dual x cooler. quiet and excellent cooling.
http://www.amazon.com/Sapphire-Radeo...dp/B0098HW1HG/
blackened23
8,548
You really can't beat the 7950 @ sale prices with 3 games for value. I've seen it for 260$-270$ on sale at various times.
Sohaltang
854
I say spend the extra $$ on a 7970. If you wanna overclock the 7870 MYST is pretty crazy for 230$. That extra 70$ will get you a small SSD or something. Even a couple bottles of whiskey ;)
Barfo
27,539
212
How do I know which 7950 models include the free games?
Thanks but I don't plan to OC the card, and I'm not sure the 7970's perf advantage over the 7950 is worth another $100.
Face2Face
4,100
215
UNhooked
1,538
You can get the 7970 for a few more $$$ new or $300 used. I got one of mine for that price. I have also seen them go as low as $275
Barfo
27,539
212
Well crap, my case can only take cards shorter than 10.5 in, and the Gigabyte and Sapphire are longer than that. Are there any short 7950s?
Rezist
726
There should be shorter ones i have the gb 7950 windforce and it's a 7970 pcb also 1ghz stock
