What is the best CPU around the $200 point for running a virtual machine box? I would assume that main board pricing for either Intel or AMD would be within spitting distance of each other.
Thx,
Jin.
AMD gets you more dedicated cores for the money, with a Phenom II X6 (6 of them). Intel's i5-2500 (K, if you're going to build it) sits right at that price point, and typically offers much more performance per core.
Beyond that, it's a wash, unless you want cheap ECC support, AES-NI support, or have use for far superior performance per core over having more cores. I guess a better way to say that would be as a question: since any modern CPU can run Virtualbox and make use of hardware virtualization support, what are your specific needs per-VM, how many are you going to run, etc.?
Mobo prices aren't quite within spitting distance of each other, but if the extra performance from Intel floats your boat, that shouldn't be a big deal, and you can always get spendy w/ AMD boards, if you want to.
Now, I assume that this is a desktop PC, since you're running Virtualbox, right? If running servers, Xen would be the way to go, and server CPUs might be better fits, depending on needs.
Right now it's simply to Virtualize a Win2K Server, Win2003 server and a Vista Desktop. I could see another VM or two in the future...
I guess I should look at something with the ability to support ECC. I have seen people say with the quality of RAM out there that ECC is bringing in greatly diminished returns.
Thx.
Get a decent 4 core and lots of ram. The problem with Ecc as choosing that forces your hand on Motherboard, CPU, and platform options, all of which come at premiums.
Is this for work or for practice?
Or a performance loss per core, as quite a few affordable AM3/AM3+ mobos support ECC, while Intel only has support on server parts.Get a decent 4 core and lots of ram. The problem with Ecc as choosing that forces your hand on Motherboard, CPU, and platform options, all of which come at premiums.
ECC support comes at no extra cost with AMD. A 1055t with an ASUS AM3+ board and cheap unregistered ecc ddr1333 from kingston is a robust platform for VMs.
VT-d is only really needed if you are performance-limited by storage or network, due to multiple VMs trying to use too much IO at the same time.
P.S. I had no idea the plain 2500 supported it...that's just weird.
What's with the tiny font? And thanks for the clarification.
Don't you mean copy/paste? And do you have pre-prepared responses for the various forums? 😕Sorry Bryan, I always write my posts that are more then a line long in word and then cut and paste. In word I use Calibri at a 11 font size but some times when I cut and paste it changes it.
