Best 1gig Ready boost drive
littlebitstrouds
410
I refuse to invest in any more ddr for my pc at home. I will be putting Vista on it though. It already has 1 gig of ram, knowing that it's good to match ram to ready boost size, I am looking for the best performing ready boost drive to match with it. Any ideas?
Bill Kunert
Some time back one of these sites had a rating on various usb drives as far as speed was concerned. I don't remember where it was but you might do a Google.
n7
21,281
4
I wouldn't get only 1 GB when usb drives are so cheap.
I use a 2 GB OCZ Rally 2; they're dirt cheap on sales here in Canaduh.
zephyrprime
7,512
Ram is sooo much better. Readyboost hardly provides any benefit compared to more ram.
n7
21,281
4
I'd disagree somewhat.
Certainly RAM is more important, but if you have 2 GB already, throwing in a cheap 2 GB Readboost drive isn't a bad idea.
Then again, if you can afford to go to 4 GB RAM (assuming you don't mind running Vista 64), then by all means, do that.
With Vista, i don't think you can really have too much RAM, & Readyboost is a nice extension of that for those who don't want to jump to Vista 64.
I am thinking about upgrading my 4 GB RAM + 2 GB Readyboost to 4 GB Readyboost.
betasub
2,677
All very nice, but what about OP's position: 1GB DDR. Is xGB Readyboost going to be better than sinking $ into adding another 1GB of DDR?
littlebitstrouds
410
Yeah this is my question's point, I will probably be upgrading to a ddr2 setup or even ddr3 (provided it's a proven choice) sometime soon. After that my "backup" rig with only 1 gig ddr will be just fine as my htpc in my living room, so I see no reason to buy more ddr right now when readyboost could be a viable option.
Most reviews that I've seen are a bit old and I know flash is a technology that is constantly getting better and better. So I was wondering if anyone had any good tips. While I appreciate the advice, I fully understand what I am asking: simply, from experience or whatever knowledge base, what would you recomend for a good 1-2 gig flash drive that will primarily be used for ready boost. Thanks
Mem
21,476
13
I'm using PEAK II Xtreme 200X USB 2.0 Flash Drive 4GB,link. with my Vista x64,fast and does the job.
mercanucaribe
Banned
Oct 20, 2004
9,763
Flash drives are slower than hard drives. Write speeds are usually something like 5MB/sec, read is 10. RAM is cheap now.
krotchy
1,942
I heard the corsair turboflash is the best way to go for these. They cost like 25 bucks at the egg.
