Best 1GB mem kit for Athlon 3500+ overclocking
obeseotron
Title basically says it all, what's the best 1GB memory kit for socket 939 overclocking under $300?
Lyfer
5,842
OCZ PC3500/3700 EB or OCZ PC3200 Platinum PC3200 EL if your on a budget (only $123 per 512mb stick at monarchcomputer.com).
ponyo
19,688
2,811
Komusa Adata PC4000 ram. $238 for gig shipped free. These will do around 270 FSB or so. If you need near 300 FSB, try the PC4200. Be sure to select Adata under Brand option. Komusa PC4000
bucd
1,106
I second that. This is the route i'm taking once i save some more $$$.
-D
obeseotron
Thanks, I just ordered the Adata, can't wait. It's the last thing I need to complete my upgrade from a p4 1.8@2.4, 512mb ddr370 (single channel), gf 4 ti4400 to a a64 3500, 1GB DDR500 (dual channel), gf6 6800gt.
