Best 19" Monitor? 900NF vs E400
JavaMomma
701
I am having problems making up my mind, the Samsung one is a bit cheaper too though...
What do you guys think? trying to spend less then $700 CAN .. The less i spend the better, but i want a good monitor.
Samsung 900NF
Model No.: 900nf
19"(18" Viewable)
0.25mm dot pitch (Aperture Grille)
2048 x 1536 @ 69Hz Maximum Resolution
Natural Flat Tube, Up To 240Mhz Pixel Frequency
ARAS surface treatment
On Screen Digital Display Director
Plug & Play Compatibility
TCO'99/MPR-II/NUTEK certified
Color Solution ( Colorific s/w )
Sony E400
19" FD Trinitron® with HiDensity? Electron Gun
Viewable Image Size
18.0"
Aperture Grille Pitch
0.24mm-0.25mm (variable)
Screen Treatment
High Contrast AR Coating
Horizontal Scan Range
30-107kHz
Vertical Scan Range
48-120Hz
Maximum Resolution
1800 x 1440 @ 70Hz
Recommended Resolution
1280 x 1024 @ 85Hz
1600 x 1200 @ 85Hz
toph99
5,505
i love my 900NF, so i suppose i'm biased :p
oh, and mine was $654cnd, with taxes it was ~$751 :)
Howard
47,982
11
Samsung 900NF. Considering both are flatscreens, chances are the slight geometry problems will occur on both.
BChico
2,742
I looked at all three of these moniters next too each other: G400, 900NF, and Viewsonic PF790, the 790 looked the clearest and sharpest, so i bought it, that was last night, hooked it up this morning, beautiful, by the way my last moniter was the 900NF and i sold it to get this one, just my input, no one ever considers the viewsonics on this forum why???
Just my 2 cents...
Macro2
4,874
Because compared to Sony, Viewsonic is a level down...
Samsung is a better brand too...
Mac
NaughtyusMaximus
900NF is comparable to the Sony G400, not the E400.
So of those two, the Samsung is the one to get.
(I own one. I like it very much)
BChico
2,742
I am not biased, i want the best, and the viewsonic looked the best to me, maybe my eyes dont work as well as the rest of you....
ToBeMe
5,711
I had a Viewsonic........just not in the same league IMHO.......in every aspect, refresh rates, crispness, clearness........and I look at these things everyday doing CAD! I haven't had the Samsung until just very recently but so far it seems very comparabale to the Sony I had at my old job!
bluesky
1,325
Well, BChico, I can relate to you.
When I saw E400 and PF790 at Compusa, the 790 was sharper and brighter.
But no 900NF was there.
Syborg1211
3,297
26
900nf totally beats out the e400, but the g400 is a closer competitor to the 900nf. I would still get the 900nf anyways.
Midnight Rambler
The 900NF over a Sony? Never.
It's not even the best DiamondTron monitor ... ;)
Also, the spec should read 0.25-0.27 for the "stripe pitch" on the Samsung. It's the same for all DiamondTron CRTs.
You can get the E400 for $409US from Staples ...
ajb35
316
Viewsonic is by no means a level lower than Sony or Samsung. Viewsonic, Sony, and Samsung are all top notch quality. I will even go as far to say that you are less likely to have geometry problems with a Viewsonic than you would the other two. All viewsonic monitors are rock solid reliable (until ups gets a hold of them...).
AMB
2,587
I like my Sony G400, I wouldnt see why anyone WOULDN'T want to buy it.
E36M3
Banned
Jan 28, 2001
73
I work at a local CompUSA and look at these things all day long. I wouldn't be caught dead with that Samsung. The one we sell is only a shadow mask monitor. Not a true trinitron. It is the 955.Maybe they are slightly different? I don't know, but I do know it looks like ass. My E400 is an awesome monitor that beats the Sams for color and clarity any day. I bought 2 of them, neither has any perceivable distrotion, either. If I remember correctly, the Samsung monitor and Mitsubish tubes anyway. I had a Mitsubishi 900u and the color was definitely inferior to my Sony. The PF790 looked great, good colors and all, but the Sony had great color and clarity.
To me, who sells them all the time, I think the sony is a better buy. It is more expensive where I work, but maybe not in your area? The best thing to do is go and look for yourself. Many may diagree with me, many will agree, I think that it is different for everyone.
EluderThe best thing to do is go and look for yourself.
andrey
Best 19" monitor? Definetely, both hands down Sony GDM-F400. Look at that monitor once and you'll understand.
Noriaki
13,640
E36M3: The Samsung 955DF is their 'budget' 19", the 900NF is higher end.
I've never seen a Sony E400 in action, so I can't compare. But I do know that the 900NF has a spec sheet more akin to the G400, so my first guess would be that the 900NF is better than the E400. I prefer the Sony G400 to the Samsung 900NF (though there is quite a price gap), but I don't know how the E400 factors in.
Of course, you could just ditch all these weeny monitors and get a real monitor, the Sony F series is unbeatable ;)
Seriously though, for less than $700CAD you probably want the Samsun 900NF. Especially if it's cheaper than the E400, the 900NF is a good monitor in my opinion. I'm not the best judge of monitor quality, but with the number of happy users in here you're probably good to go.
Biggs
3,010
This is like beating a dead horse but the bottom line is no monitors are created equal. You may get unlucky and get a sub-par Sony G400 so it's really the luck of the draw. From a price/performance standpoint, nothing beats the Samsung 900NF and that is true! :)
