Best $100 or less Small Form PC for Uptime
j03h4gLund
354
I plan on running a ZNC bouncer. And maybe a plex media server.
Was looking at ASRock Deskmini 110W which goes on sale for $90 tomorrow for the week of Black Friday
I really want something with great stability and longevity.
VirtualLarry
56,587
10,225
Amusingly, or perhaps not, I've found my DeskMini units (I own three of them, thus far), to be less than 100% stable. Some of them suffer from spontaneous reboots and the like. (Not just updates.)
Ken g6
Moderator
Dec 11, 1999
16,729
4,703
75
I got a "refurbished" Deskmini. It turned out the motherboard was a mess, and probably shorted out. So I got a different brand of motherboard. It mostly fit, except the SATA ports are on the top, not the bottom. So I can only run it with USB drives or a M.2 drive. Point is, if you have to replace the mobo your options may be limited with a Deskmini.
Rifter
751
Its over $100 but not by alot. I bought a QOTOM Q310G4 to use as my pfsense firewall/router box and its been up since i got it 10 months ago. No crashes. Only time its been reset is when needed for an update. Its been the definition of rock solid for me.
