Benchmark your computer with Handbrake
wsaenotsock
90
HandBrake 0.9.9.5470 - 32bit Version
OS: Microsoft Windows NT 6.1.7600.0
CPU: Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
Ram: 16269 MB
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2
[21:15:01] work: average encoding speed for job is 195.117599 fps
moonbogg
10,637
3,095
If you do what was mentioned here : "Go to Options > Advanced, tick "Put a copy of individual encode logs in the same location as the encoded video". Upon finishing, check the log file."
You should have a log file that will give you the exact info.
Well thank you and yes I followed the instructions. Upon viewing the log file I was confronted with a massive wall of text which I combed through several times and nothing shows average fps anywhere like others have posted.
GOT IT. It was buried in the middle. Good god.
work: average encoding speed for job is 331.410828 fps
SPBHM
5,059
413
stock i3 2100, DDR3 1333.
HandBrake svn5614 (Nightly Build) - 64bit Version
OS: Microsoft Windows NT 6.2.9200.0
CPU: Intel(R) Core(TM) i3-2100 CPU @ 3.10GHz
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX
[02:07:14] work: average encoding speed for job is 89.590996 fps
same software, with HT off the result is 74.638855 fps
on Windows XP SP3 (32bit) with HT ON and no AVX the result is 82.002769 fps
HandBrake 0.9.9.5530 - 64bit Version
[01:57:26] work: average encoding speed for job is 84.420723 fps
Invalid
123
OS: Microsoft Windows NT 6.1.7601 Service Pack 1
CPU: Intel(R) Core(TM) i7-3930K CPU @ 3.20GHz
Ram: 16357 MB, Screen: 1920x1200
[01:20:53] work: average encoding speed for job is 333.286713 fps
Edgemeal
211
57
101
If only text viewers had a way to search or find text, oh wait... ;)
Nice! Whats the PC specs?
AtenRa
14,003
3,361
CPU: AMD A10-6800K (4.8GHz) APU with Radeon(tm) HD Graphics
Ram: 6088 MB, Screen: 1920x1080
[09:09:28] starting job
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX XOP FMA4 FMA3 SSEMisalign LZCNT BMI1
[09:11:17] work: average encoding speed for job is 130.980011 fps
unixwizzard
205
cpu peak of 4.1ghz @ 1.25v, memory @ 1.6ghz
CPU: Intel(R) Core(TM) i7-3770 CPU @ 3.40GHz
Ram: 16261 MB, Screen: 1920x1080
[02:09:19] work: average encoding speed for job is 251.153595 fps
I guess this is good, no? :p
Centauri
1,628
54
AMD A10 5800K downclocked to 3.2GHz. IGP @ 1169MHz. 8GBs of 2133 RAM.
CPU: AMD A10-5800K APU with Radeon(tm) HD Graphics
Ram: 7123 MB, Screen: 1600x1200
[23:47:12] work: average encoding speed for job is 92.001625 fps
And nightly;
[00:10:15] work: average encoding speed for job is 93.941826 fps
BallaTheFeared
8,115
Thanks for the enlightening info.
3930k @ 4.3
16gb DDR3 @ 1600
Well now I don't feel so bad about losing by 31 fps...
I don't think I can match it, at least not without delidding and/or hooking it up to water.
Edit: I can finish @ 5.2GHz (I could try higher, but I have a $50 air cooler and temps are quite high for the voltage I'd need to push through it), but I need to drop my ram.. Haswell sadwell :(
Even 4.9 won't post past 2000MHz, anything after that it's 1600 or it won't post.
Without cpuz and realtemp this will score between 299 and 302 FPS (Nightly).
It's kind of sad I get cut off at 4.8GHz 1.25v before I have to sacrifice other aspects of performance. I see other people running these chips upwards of 1.35 even 1.4v or higher with proper cooling. I don't think it would even matter if I delidded or used water, I think this is the optimal settings for the chip, or basically the fat lady has sung.
Sable
1,129
101
4.6 1.155v
[17:50:50] work: average encoding speed for job is 288.914917 fps
CPU: Intel(R) Core(TM) i5-2500K CPU @ 4.6Ghz (1.34V)
Ram: 8137 MB, Screen: 1920x1080
[09:01:31] work: average encoding speed for job is 218.507355 fps
For the same clock speed there's a 70fps increase from Sandy to Haswell. And at much lower voltage as well. HASWELL IS TEH SUXZ0RZ!!! ;)
SPBHM
5,059
413
quite impressive difference indeed, Haswell I7 shouldn't have much trouble competing with 6 core sandy-e on this benchmark.
BallaTheFeared
8,115
Software should be more mature in a few years, gives you something to look forward to with Haswell-e at least ;)
Zoeff
86
For SCIENCE!
i7 4770K @ 4.5Ghz 1.27v
4x4GB RAM @ 2133Mhz
[15:04:12] work: average encoding speed for job is 301.439270 fps
I wonder if I can get that a little bit higher with a fresh boot...
YBS1
1,945
129
There is no replacement for displacement...
[09:21:13] work: average encoding speed for job is 404.117493 fps
Ram: 32709 MB, Screen: 1920x1080
@4.8GHz
Carfax83
6,841
1,536
[08:52:54] work: average encoding speed for job is 346.908142 fps
Ram: 16322 MB, Screen: 2560x1440
What the hell is the "(Nightly Build)?"
JoeRambo
1,814
2,105
nightly:
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX AVX2 FMA3 LZCNT BMI2
x264 [info]: profile Main, level 3.0
[17:50:05] reader: done. 1 scr changes
[17:50:05] work: average encoding speed for job is 324.526733 fps
4770k @ 4.5Ghz
Soulkeeper
6,714
143
Encoding: task 1 of 1, 99.99 % (330.62 fps, avg 310.87 fps, ETA 00h00m00s)[08:08:14] render: lost time: 0 (0 frames)
work: average encoding speed for job is 310.870636 fps
System in my sig running slackware64
Jodell88
8,762
30
o_O
