- Jun 8, 2001
- 9,574
- 2
- 76
Problem found and fixed, thanks guys
Have a 98 Ram that I need to replace the belt on (never done it before).
The belt tensioner is on the left side and to test things our I turned the bolt clockwise. That moved the pulley to the right, but it did not swing back into its original position. Is that normal? If so, how would I determine what exact position it should be at when I replace the belt?
