Ok, so I have had some squealing for the past month or so, only happens when I first turn on the car afters it's been sitting for awhile, and only happens for about 10 seconds when I first put it in reverse to back up or in 1st to start moving forward. After that, it won't squeal again for the rest of the drive.
Figured it was the belts, so I replaced both (a/c/p/s and alternator) of them this morning, went pretty well.
After replacement let the car sit for awhile, then went out and started it, seemed fine. Ran some errands, and after leaving Best Buy, it started to squeal again. It didn't seem as loud or go for as long, at least that's what I thought. But it's still squealing.
Any thoughts? I will try tightening the belts up a bit, but what else could be causing the problem? Something related to the pulleys? Alternator? Or is it most likely related to them being too loose?
By the way this is a 2002 Protege ES, just short of 70K miles.
Thanks.
Thanks.
