- Apr 17, 2003
- 37,622
- 0
- 76
Originally posted by: Corporate Thug
so if you know how to use a cross over cable, there is no difference?
Originally posted by: Nuwave
In addition to crusty
Hi-Speed USB 2.0 is a 480 Mbps interface
No, there's a big difference. Using a crossover cable will only get network connectivity between two machines without a switch/hub in the middle. The Belkin cable is a USB device that you can use with their software to facilitate the transfer of files/settings between the two computers.
would there be any difference (other than theoretical speed) if I was to do PURELY file transfers (in other words, I'm not transferring settings, .exes, etc...) ?
Originally posted by: vailr
If both ethernet ports are Gigabit, then there shouldn't be a need for a specifically "crossover" type cable.
The Gigabit port spec includes auto-sense for correct operation when connected with either cable type.
