- Jan 6, 2008
- 9
- 0
- 0
AMD Athlon(tm) 64 X2 Dual Core Processor 4000+
radion hd 3950 (512MB)
asus m2a-vm mobo
Can't raise the CPU multiplier (10.5).
Have raised the CPU Bus speed to 210, anything above that not stable with everything else auto or default.
Tried raising Bus Speed to 220 and and the Core Voltage as high as 1.500 (default: 1.31), not stable.
I've read about raising the HT, should I try? Anything else (simpler the better)?
I would really like to get to this up to 2.4 Ghz if possible? Only running at 30-32C idle right now, so cooling probably not a problem (please tell me if I'm wrong).
asus m2a-vm mobo
