before it wouldnt post now there no power....
Dec 9, 2006
66
Okay ived allready made a topic but nothing really happened...but my pc havent worked since mid november all it does on a power on was that it would start up but the cpu fan wouldnt move... then shut off after approx 5 seconds. So i just got my new psu cause i thought that was the problem(corsair 620W HX). Now the pc wont even start up...at all. I can see the cpu and the gfx fan move a tiny bit...but nothing. If i take out the pci e stick from the gfx then the mobo makes the alert sound of no power to the gfx. So it seems like the psu is working.... this is so messed up i cant find the damn faluty bit in my pc and its ruined me so far... hate this. Hope anyone can help.
RadiclDreamer
8,622
40
CPU fan plugged into the right port? Some systems will shutdown the system if it doesnt detect a fan. So if you have the fan plugged into say a case fan port it would possibly cause this issue
robisbell
Banned
Oct 27, 2007
3,621
like I stated in the other post, the odd valued PSU's seem to have more issues.
I'd manually test the voltages of the PSU.
