Before I pull all my hair out need help with voltages
EQTitan
4,031
I'm running:
Stats courtesy of CPU-z
AM2 Bristbane 5000+ (non-BE) 1.296V (is that to low?)
2x 1Gb Crucial Ballistix PC2 6400 (400mhz) DDR2 1066 2.2V **Dram Freq. 371.5MHz**
Biostar TA790GX A2+ r5.1 newest bios
Is that cpu under clocked?
mpilchfamily
3,559
If the system is running good and stable with a lower then normal vcore then thats a good thing. It means it will run cooler and use less power.
EQTitan
4,031
I'm going to try this again, I bought the following put it all together without changing anything in the BIOS it worked for 3 weeks then I started getting corrupt data, and BSOD's.
TA790GX A2+ r5.1 (newest BIOS)
AM2 Bristbane 5000+ (non-BE) (stock 1.325V my computer 1.295V)
2x 1Gb Crucial Ballistix DDR2 1066 (stock voltage is 2.2V my computer ran it at 1.8V clocked down 7x)
Antec True Power 2.0 500w dedicated 12V+1 18A 12V+2 18A
Seagate SATA 250Gb HDD
I've run memtest+ that comes built in to motherboard which gave a ton of errors running ram at 1.8V, ran test again with ram at 2.2V and had no errors.
I've run Seagate Hard drive utilities and it's fine.
I reformatted the computer with Win XP SP3. installed all the drivers, chipset software (got an error trying to install this stating the device did not exist)
I also read some where that my Avast! anti-virus was causing data corruption and the BSOD not playing nice with other software....
