Originally posted by: sactoking
Bah, Paula Deen is about as unknowledgeable as Racheal Ray or Emeril, just not quite as annoying.
Originally posted by: spidey07
Sautee onions in skillet, poor good dark beer in skillet. Poach brats for a bout 15-20 minutes. DO NOT BOIL!!!!! You want the water around 140-160 degrees or just warm enough that a wisper of steam is coming off. Then finish on the grill turning frequently.
i don't know if dark ber is really the flavor that i woudl look to for beet brats, something more like a pale ale or lager sounds better.
You can go with dark beer without fear. The brats get a little flavor from the beer, but not all that much. They won't wind up tasting like the beer no matter what you use. I, and many other brat lovers, use stronger beers precisely because the brats pick up so little of the character.
Originally posted by: AmigaMan
damn, I have been doing it bassackwards all along. While I did cook them at a low low temp on the grill, they always stayed on until they split because I wanted to make sure they were done. Then I soaked them in boiling beer after they're done. They don't taste bad at all, but they are a little dry.
Doesn't she use ketchup a lot? Don't know of any self-respecting cooks that use it.Originally posted by: sactoking
Originally posted by: TallBill
Hmm, I don't have hours to simmer, will they still pick up extra flavor in like 30 minutes?
Originally posted by: Kelemvor
Make sure you poke holes in them with a fork so the beer can really get inside. Stick them in a huge pot on the stove and vook them up. THen grill them.
When you're done grilling, you could drop them into another hot container of beer to keep them warm But normally it's better to just eat them right off the grill.
Originally posted by: MrLee
Just to throw into the mix here, I've vaccum sealed brats in beer before for about 4 days in the fridge. The come out just as awesome.
That certainly wouldn't hurt them any.
The important thing is to keep the skin intact. That means cooking slowly by simmering and NEVER EVER pierce the skin. The minute anyone suggest piercing the skin on a brat you must ignore everything that person says about food for all eternity.
Bad advice.
The worst thing you can do is prick the skin and let all the juices escape especially when they are fresh from the pot or grill. The beer will still get in and flavor them from the ends, so poking holes in them is not necessary.
<--- Bratmaster in my house!
Piercing the casing lets more of the fat juice outOriginally posted by: Kelemvor
ok - I hope you're kidding. If you're not then take care to cook some good brats.
Needless to say a brat should explode in your mouth with a flavor, snap and more moisture than your tongue knows what to do with that can't be described.
1) Don't you dare break the casing, if you do the heat is too high
2) If grilling, cook over medium heat AT MOST. No matter if you poach them in beer or not you CANNOT break the casing. turn the brats every two minute or however you know your grill and the heat. If they are spewing juice, you broke the casing - that means you didn't turn them enough or your heat is too high.
3) Did I mention not to break the casing?
Make sure you are purchasing uncooked brats. If you poach them as described above in beer they are mostly cooked through (in fact as suggested you can poach them for longer but you can and will overdo them if you're not careful) and the grill just gives them some snap/carmalization on the casing.
Good luck and practice makes perfect.
