beatsaudio and weird echo/reverb sound
Beginner-At
61
depending on what i listen or watch, i select “music”, or “voice”, or “movie” – on the beatsaudio control panel.
it works.
but when i try to set, manually, the beatsaudio equalizer, there’s some sort of echo/reverb sound, like a helicopter (i don't know the techy name).
happens when the main volume (with the usual windows icon) is more than half
problem goes away if i click on beatsaudio equalizer's “default” icon.
if there's no solution, is it possible to uninstall the beatsaudio app, and only use the normal, usual, windows stuff?
Thank you very much
