boomerang
- Jun 19, 2000
- 18,883
- 641
- 126
Well, you know what caused the problem. In this case, that's actually a good thing.Originally posted by: illusion88
I didn't get the oil changed for about 5-6k miles. I know, bad. I must also have a small leak or it's burning oil. A friend of mine told me that all Honda engines burn a bit of oil. Not sure if that's correct or not. Either way, when I checked my oil after the knock started I was bone dry. I added 3 qts of oil and it just put it inbetween the lines on the dipstick.
So the route of the problem is a combination of me not changing the oil and the oil either leaking or burning over 5-6k miles.
Two of the caps and rod ends are discolored. Those are the two that had the burnt bearings. The cradle isn't discolored. It also fits back in easily. I haven't been able to get to the main journals, how much risk is it to just leave them there and hope for the best? Is that straight retarded?
I don't have an oil pressure gauge, but I bet Napa autoparts carries one.
To answer your question, I would change all the bearings.
Here's an old trick for removing upper bearing shells on main journals: You can only use this trick if the crankshaft is cross drilled. In other words, if there is an oil hole in the main journal. Get a cotter pin and bend it such that when you put it in the oil hole and turn the crank, it will butt up against the edge of the bearing shell and spin it out. Obviously, you want it to contact the shell only and not scrape the block as you turn the crank. Make sure you spin the crank in the correct direction. Pay attention to the tang on the bearing. It can only come out one way.
I can tell that you are going to replace what you can and hope for the best. That's OK, lots of folks learn from their mistakes. I have one question for you and then I'll let you have at it. Where did all that damaged bearing material go?
