- Jun 5, 2008
- 5,514
- 1,723
- 136
be quiet! Shadow Wings 2 120mm PWM White, case fan, airflow-optimized fan blades, whisper-quiet operation and reliable cooling $8.90 free s&h
www.newegg.com
-The white colored Shadow Wings 2 120mm PWM offers whisper-quiet operation and reliable cooling at low revolutions per minute. Key features include:
-Low-noise operation of up to 15.9dB(A) even at its maximum speed of 1,100 rpm
-Airflow-optimized fan blades, resulting in a whisper-quiet operation yet solid cooling
-Anti-vibration mounting system that prevents transmission of vibrations to your PC case
-Rubberized fan frame minimizes vibrations
-High-grade rifle-bearing technology that contributes to an operating lifetime of 80,000 hours
-Secure and easy installation of the fan with push-pins
-PWM controlled fan speed through the motherboard
-Product conception, design and quality control in Germany
-3-year manufacturer’s warranty
-Shadow Wings 2 fans are the perfect choice for all who appreciate maximum silence for their PC case.
Are you a human?
