Originally posted by: Insidious
as of 1972, my BBC world has come to a crashing end... (taking BOINC with it of course)
It was a good run. but now it's dun 🙁
-Sid
all condolances are appreciated![]()
I had managed to convince myself I had one that was going to go all the way. 😕
(but I knew from our team mates that wasn't really a given)
@RD, I don't know why it always takes BOINCmanager with it when it goes. It did on every crash (I think I was up to 5 or 6 🙁 ) It gave the error 'Boinc manager cannot comunicate with localhost'.
I used add/remove programs to uninstall BOINC then re-installed. The remaining projects took up where they left off so it isn't so bad.
But look at it this way.. it took Nuclear Winter and a dehydrated VodCOW to doom me.... 😛
-Sid
:shocked: I OWNED a T.Rex album when I was in HS. I had a friend jamed Jeff who we all called Jake and he ate crap everytime the song 'Jungle Faced Jake' came on. (yes, Jeff had some serious acne :laugh: )
Watch out where the VODcows go........... Don't you eat that yellow snow! :shocked:
:laugh:
They was initially planning to split hindcast/forecast in 2, but decided against it since different cpu/OS will give different result...Originally posted by: Assimilator1
Why do they have to have such massive WUs anyway??😕 ,surely that's just asking for trouble?
Sorry to hear it Peter.
It is disappointing to have so much time go up in smoke.
I think this project is perhaps simply not competent.
-Sid
(not sorry I tried.... :thumbsup: )
Originally posted by: petrusbroder
🙁 I am very sad to report that one of my two comps with BBC-CCE crashed due to "Beräkningsfel" (in swedish): Computation error, at exactly 50.0%;
Also, you'll most likely get much bigger uploads/downloads whan now...
As for very long model, well, at the start-date you've also got a 200-year Spin-up model as a basis, the ocean needs very long initializing...
Also, the 80-year hindcast-period is run to see how close to reality a particular model is, if hindcast is very close to reality the probability forecast is also correct is higher than if a model lead to a new ice-age in 1972...
I don't see why different OSs or CPUs would give different results ,they don't on all the other DC projects *shrug*
LHC@Home FAQ5.4.2005 8:06 UTC
The new sixtrack application seems to run fine but we will have to do a final analysis on the results.
We are not yet using the new BOINC api, because this requires a lot of changes to the way we do graphics.
Before we made these changes we wanted to test the new physics code. Version 4.66 uses the CRlibm library. This will hopefully remove the differing results we have seen from different platforms.
Please note that different CPU architectures may yield different floating point results. This is especially true between Pentium and Athlon XP CPUs.
BOINC, Eliminating discrepanciesMost numerical applications produce different outcomes for a given workunit depending on the machine architecture, operating system, compiler, and compiler flags. For some applications these discrepancies produce only small differences in the final output, and results can be validated using a 'fuzzy comparison' function that allows for deviations of a few percent.
Other applications are 'divergent' in the sense that small numerical differences lead to unpredictably large differences in the final output. For such applications it may be difficult to distinguish between results that are correct but differ because of numerical discrepancies, and results that are erroneous. The 'fuzzy comparison' approach does not work for such applications.
Did even stumble over a small Folding@home-quote indicating disrepancies also here, Folding-forum, Vijay PandeGiven all this I was delighted, until I started finding small numerical difference in a small percentage of runs. This was relatively easy to spot, as even a difference of 1 in the least significant bit of the mantissa of an IEEE floating-point number, will be magnified as the SixTrack particles pass through ~10,000 computational steps of each of up to one million turns.
The differences between CPUs are not important when trajectories are taken statistically. As it is, any single trajectory isn't all that useful, but as a whole, we can learn a lot.
