i cant believe ppl are using more than 100%.
This game supports other AA methods, there is no need to destroy your performance like this.
Some people have the graphics power on here. Don't see why they wouldn't.
Downsampling doesn't AA all edges since it's only an ordered grid. SGSSAA is really the best, by far.Say you run the game at 1920x1080p, you can run the game at 2880x1620 internally and it will output to your monitor at 1080p delivering a much better image and negating the need for running MSAA/post-AA
I just want to confirm that setting it below 100% has no effect on performance... Also, I need to build my PC now! 😛
Whoops, derp mode was engaged.
That was system memory I posted.
Here is vram usage at 1080p 200% and 4xMSAA
You have to divide by two, but I'm also pretty sure I got some stutter from the buffer.
Wow.. they were not kidding with the whole 3GB Vram recommend thing..
If it doesn't effect your frame rates, it means you are already CPU bottlenecked.
Is that 4xMSAA Face?
When the game is so horrifically CPU limited, people have to have something to do with their 3xTitan SLI rigs :awe:
It uses less CPU than BF3, way less.
