Cloudfire777
Pretty interesting. I thought 1600MHz was more than good enough.
http://www.corsair.com/us/blog/bf4-loves-high-speed-memory/
Interestingly, Battlefield 4 takes a pretty holistic approach to the system it runs on. Isolating bottlenecks used to be pretty easy: you were either CPU limited or GPU limited. Either your graphics hardware was holding you back or your processor was. As long as you weren’t running 4GB or less system memory, RAM wasn’t an issue. Yet with Battlefield 4, your RAM is important again in more ways than you might have expected.
I’ve been doing testing on Haswell to determine whether or not higher speed memory could improve system and specifically gaming performance, especially with multi-GPU systems. My intuition and some of the research I’ve read online suggests that Haswell’s “sweet spot” memory speed has actually jumped from the time-honored 1600MHz to 1866MHz. What I found with Battlefield 4 is remarkable, though. Testing on an i7-4770K overclocked to 4.4GHz and two overclocked GeForce GTX 780s in SLI, I discovered that memory speed affects Battlefield 4 performance in a very measurable and perceptible way. Check this out:
Running at 1920x1200, or slightly above the most common resolution of 1920x1080, bumping our 32GB of Dominator Platinum from DDR3-1600 to its XMP speed of DDR3-2400 raised the average framerate a staggering 22.7% and the minimum framerate a still impressive 9.7%
