So what's the point of having a home battery?
So you can use Solar to get off the grid.
I don't think it's the utility's choice. I believe it's regulated by the governmentSomething like this is going to be needed if Solar is going to go anywhere since it's pretty much inevitable that the utilities are going to stop net metering eventually or seriously curtail how much you can save by sending power to the grid.
We don't. Arcs with switching is a problem. AC is safer.So when do we switch to DC-power in the home.
Deep cycle batteries, not car batteries. Boat batteries. I suppose it's useful to have a bank of batteries in case of a power outage. But, it's far more logical to insert any extra energy produced during the day into the grid - and then get power from the grid at night when the solar isn't producing anything. Reason: during the day, more power is used as a result of industries. Saving your own energy isn't 100% efficient. That is, if you produce 10 excess kilowatt hours during the day, if you save that energy in a bank of batteries, you're only going to be able to use 7 or 8 of those kilowatt hours of energy during the night. Tis far more efficient to insert that 10 kw-hrs into the grid, then get your 10kw-hrs back during the night. Not to mention the required storage space, plus cost of all those deep cell batteries (they're not cheap).I would be happy if they made a conversion kit that had the electronics and volt conversion and regulation that would allow us to throw say 12-20 car batteries for 2-4 years to do the same function. I bet its gonna be MUCH cheaper than what they what to do because those batteries are not cheap.
You an squeeze more than a billion transistors into one square inch.They would be to a small degree if the F-ing panels were not so damm expensive, I can't understand why everything else from microprocessors to CCD's to RAM all have been vastly improved and plummeted in price in the last 25 years yet no one seems to be able to bring an affordable solar panel to market. Yea, I realize that part of the price is the installation but the killer cost is still the panels themselves.
Possible substitute for a backup generator, whether it be a noisy gas-fueled unit or a propane one with a sizable tank.So what's the point of having a home battery?
https://www.youtube.com/watch?v=Zez2r1RPpWY
So it's just an extension of solar/wind power which have existed for decades. What's new about this technology?
The cost of solar + batteries is or very soon will be less than the cost of grid power...in Germany. But that's without the Tesla Gigafactory.
With the Gigafactory a similar situation has been predicted in the USA for some time.
You'll still need to pass the DC through a regulator to get a voltage that the LEDs like, preferably through an efficient constant current regulator.to take advantage of solar use in the home, they need to develop DC lighting systems. LEDs are DC, and not having to convert back and forth will save energy and money. A big part of the cost of LED bulbs is the build in DC supply.
If your small loads could be DC in the home, a small battery bank/solar panels make sense.
Would they? 12V powers the cards, but nothing on the card (except the fan) actually runs at 12V. Going from 12V down to the 2V or less that the card uses already produces a fair bit of heat at its regulators. Pushing 48V to it would just make that worse.
Well that's one website that doesn't deserve to get read anymore.
Yes, I'm sure the electric company is terrified of a battery. Because, you know, batteries just make electricity. By magic.
Obviously, 'why they should be afraid of solar panels' would be more accurate...and they're not. At all.
High efficiency solar panels run in the 30~40 volt range. Lighting loads are so small with LED that amperage and wire size really does not come into play. A 36 V battery bank would have minimal charge converting, and is not high enough to give me the DC heebie jeebies.You'll still need to pass the DC through a regulator to get a voltage that the LEDs like, preferably through an efficient constant current regulator.
Or else half-ass it with a current-limiting resistor and hope it works out.
However, DC-DC can at least be done quite efficiently. While really efficient AC-DC supplies can be made, the cost and complexity tends to go up. The first drop is across the rectifier on the input, which will usually drop (input_amps*0.7)watts right from the start. Add in an active bridge with MOSFETs and you'll gain efficiency, but the cost goes up.
If you go with low-voltage DC, the amp draw goes up, and you need heavier conductors. If you go with high-voltage DC......that stuff just sounds scary.
Yes it is. Battery storage is the bottle-neck holding back global adoption of solar panels and putting corporate supplied power out of business.
You can do it for much of your lighting alreadySo when do we switch to DC-power in the home.
Tesla plans to sell a home battery this year. You could avoid having to depend on a fuel powered generator in your back yard or property. Save money on your electrical bill maybe? Well depends on the price of the battery I guess.
http://www.theverge.com/2015/2/13/8033691/why-teslas-battery-for-your-home-should-terrify-utilities
I'm still trying to search the net for the cost of recharging this thing from your regular electrical outlets. Or if you even can. Surely you can right? As long as it's cost effective to recharge it that way after it's paid itself off from the purchase price. You can recharge it from solar panels if you're lucky enough to have them.
I can't tell if Elon Musk actually believes his businesses will be eventually successful and that his dog and pony show is designed to bridge the time gap between now and when that happens or if he knows he is in trouble and is just praying for some sort of miracle.
Either way, stories like these are integral in the way Elon Musk's keeps his businesses afloat.
-KeithP
