battery replacement question - mAh, V, etc.
TheNinja
12,207
So thanks to my generic Ipod fiasco (which can also be found on ATOT) I'm looking to replace the battery. However, the battery I have now says
capacity: 250mAh
Voltage: 3.7V
(4.2V) (+) ----- whatever that line is supposed to be
I see some on ebay at 3.7V but differ from 400mAh to 330mAh and others. What ones would be safe for me? Can I go larger than 250mAh...smaller?
Thanks
FoBoT
63,084
15
fobot.com
higher mAh is good as long as it will fit (physical dimensions)
don't go smaller
mAh rating is how long it will last, how long it will power your device
TheNinja
12,207
don't go smaller
ahh...you the man FoBoT. So I might as well get a 400mAh battery as long is the size is same and it's 3.7V.
Thanks!
fuzzybabybunny
Moderator<br>Digital & Video Cameras
Moderator
Jan 2, 2006
10,455
35
What FoBoT said. mAh is basically the charge capacity of the battery, so higher is better and it'll power your device longer. But you've also gotta keep in mind that a higher capacity could mean larger physical dimensions of the battery, so make sure it'll fit.
I have no idea what the 4.2V is.
Oblivionaire
253
3 1.2V nimh batteries in series will do, 250 mah is easy to achieve, even exceed, with just AAAs. So maybe solder 3 AAAs in series? Would they fit? I don't have an ipod so I don't know how small it need be. I soldered a couple of AAs together once for an electric shaver and it works great to this day. Like Fobot said you can go larger on the mah rating but not smaller. And size is important for it to fit inside the device.
