- Apr 26, 2001
- 31,046
- 321
- 136
So I've got an 05 WRX. The battery that came with it was a piece of shit and due to a combination of not driving it very often and it going through harsh Chicago winters outside, I replaced it with a Red Top a few years ago.
That battery is now dead, it's totally my fault and I know what not to do at this point. I need to get a trickle charger.
That said, I am looking for a replacement and it seems like the Yellow Top might work out better for me? Due to a fucked up engine compartment I had to mount the Red Top sideways to fit it. I need a battery that can handle this so I figured I'd look at Optima again... the thing is, I have after market stereo stuff thats wired in and it looks like this one might handle that better? I was always told that Red Top was the go-to battery for that kind of thing but I noticed just recently they updated their page to say that car audio stuff is no longer supported under warranty whereas before that caveat was never listed. The Yellow Top does NOT have that same warning under warranty, so I figured I'd give it a shot.
Am I wasting money with this? Should I just get another RT and use the trickle? The nomenclature on that page sounds like a huge list of buzzwords and I look to you car guys to tell me if its really worth the extra cost or not.
