she bought a power book from my work this past saturday
their return policy- they will refund all of your money (no restocking fee)
but they give you a gift card (because they wanted to cut down on people "renting" laptops and pordable DVD players) you have 21 days from purchase to return it
anyway she got the computer home and started to charge it, the light went immidiately to green (which should mean its charged) but the battery showed 3% charge after 12 hours of being connected to the wall over night (if the battery is in the process of charging the light should be amber)
we bought a service plan through my work but i think its stupid to use it if its either A something that apple should be able to fix directly (i.e. sending us a good battery and we send the bad one back) or B ust returning the unit because its with in the 21 days
(we are allowed 2 battery replacements in 3 years of the plan)
problem is all of the computers in stock at my work may have a bad battery too (there are a bunch of forum discussions at apple.com about the problem sounds like a bad batch of battery's) so just echanging it may not be an option
my sis called apple (since she is with in the first 90 days of phone support) they had her do a bunch of things like holding down certain buttons when powering on and holding certain buttons with the computer off and nothing helped they insist that its not the battery and wont send her a replacement one
she told them "well i think its a bit funny that you have a forum with many people complaining about this same problem with my same symptoms, yet those people were able to have replacement battery's sent to them" the tech on the other line said she should take those with a grain of salt... WTF?
any help would be great
thanks in advanced
thanks in advanced
