Hello together,
To introduce myself, first I´m an electronics engineer and hobbyist since >20 jrs now working in Hardware fail analitics for money. In long gone days cell change of Batt packs was easy. Nowadays some unknown obstacles - for safety I know - were built in the quite expensive Battpacks. With the Help of this Forum it might be possible to bring some light in the misterious dark of the
Battery of an asus x101 model e.g. a31-x101. that is a 3 cell one.
Mine had just 30 minutes power left after 9 months powerusing
The prices for this type of batt ranges from ~40 - 90 Eur.
This was enough for me to get interrested in repairing, better changing the cells.
My Debian based OS ( I am using Knoppix ) operated eeepc x101 terminal said when using
>cat /proc/acpi/battery/BAT0/info
just some 800 mA last full capacity.
So I decided to open the Batt-Pack and check the malicious cell.
http://666kb.com/i/cay0v0kz8d59rs685.jpg
Then I connected a junsi cell-logger with some soldering and found the middle cell more than 400mV difference to the right one. Battery detached
http://666kb.com/i/cay1526ekp72xrlad.jpg
Battery connected + Adaper connected, the cell-logger told me the laptop-charging algorithm is not balancing the cells.
So i connected the removed batt pack to a separate lipo balancer charger.
Still all cells left soldered to the packs electronic in the case.
A retrial with
after offline balancing told 1670mA last full capacity.
That was feeled too optimistic due to just some minutes more now without adapter.
So I made the descision fatal.
I disconnected the cells from the battpacks electronic.
And changed the cells with some i know are good and of same capacity.
And so bricked the batt.
I could have known better, but I did not
here http://frantisek.rysanek.sweb.cz/battery.html
they describe a lot of things I did not know before desoldering.
In case someone has a working but still bad battery pack I would highly reccomend not to disconnect any of the wires from the cells to the controller. Change the cells as in an open Heart operation to keep the safety-stuff alive. see some more about this here
http://batteryuniversity.com/learn/article/how_to_repair_a_laptop_battery
well now it is to late.
The pack lies around with fully charged cells and no voltage is comming from the + terminal
still some information can be retrieved from the pack. but it remains cut off.
The voltage reading is exactly the one the cell-logger reports.
But the serial number is missing now, and the cycles is set to 0
So far i have no idea which batt controller is really inside nor how to make the reset.
Meanwhile I got a new pack from china cause i want to be mobile again.
But I want to bring the battbrick back to life but how?
here what is left
>cat /proc/acpi/battery/BAT0/state ; cat /proc/acpi/battery/BAT0/info
present: yes
capacity state: ok
charging state: charging
present rate: 0 mA
remaining capacity: 0 mAh
present voltage: 12063 mV
present: yes
design capacity: 2600 mAh
last full capacity: 1670 mAh
battery technology: rechargeable
design voltage: 10800 mV
design capacity warning: 10 mAh
design capacity low: 5 mAh
cycle count: 0
capacity granularity 1: 26 mAh
capacity granularity 2: 26 mAh
model number: X101
serial number:
>acpi -b
Battery 0: Charging, 94%, charging at zero rate - will never fully charge.
What was measured looking on the battpack terminals
- n1 n2 x3 x4 x5 x6 x7 p8 p9 +
n1 vs n2 <1ohm
n1 vs x3 <1ohm
n1 vs x4 1Mohm
n1 vs x5 125Kohm
n1 vs x6 2,2V 50ms 0V 200ms repetitive, some glitches (clock signal)
n1 vs x7 0V (assuming Data transfer for SMBus)
n1 vs p8 0V
p8 vs p9 <1ohm
I tried to connect x4 to x7 over 100 ohm with gnd. no change.
I have an old parallelport equipped laptop, would it be worth to try the I2C stuff
exierience, discussion and help is welcome.
A retrial with
here what is left
present: yes
capacity state: ok
present rate: 0 mA
present: yes
cycle count: 0
model number: X101
serial number:
>acpi -b
n1 vs n2 <1ohm
n1 vs x3 <1ohm
n1 vs x4 1Mohm
n1 vs x5 125Kohm
n1 vs p8 0V
p8 vs p9 <1ohm
