Okay, this is weird. The other day when i was putting together my new rig i couldnt quite pinpoint the problem i was having after putting it together. It wasn't posting. After resetting the bios by taking out the mobo's 3V battery, I was able to get it to post and install everything.
Now this is the problem.... I power down my computer.... If i unplug the psu cable or just simple switch it to off position, then try to plug it back in and power it up, it doesnt POST! I have to take the battery out and back in for it to post?? I've tried 3 different batteries and they all give me the same response. Could it be the PSU? Its a 500w Aspire that came with my case, so far i dont see the need to change it since it seems to be a pretty promising psu. 34amp on the 12vrail.
What could this be a sign of?? I cant figure it out.
Latest bios, drivers, updates, and patches are on my computer. I'm running Windows XP Pro SP2. I'm using the MSI Neo2 Platinum 939 with 1GB OCZ PC-4000 and the AMD64 3500+ 90nm.
Please help !!
As soon as the plug comes out of the psu or the switch is put to off position, it wont POST until i remove/replace the battery with the psu cable in the psu.
Please help !!
