Battery mAH tester
TheGizmo
3,627
I bought a battery that was supposed to be 'brand new' on eBay for my cell phone.. OEM. Well I have reason to believe that this battery has been used significantly as it doesn't hold a charge for very long. Is there some way I can test how much mah this battery holds? This is one of those principle things. I'd pay as much as I paid for the battery to prove the guy wrong, so let me know what you can suggest.
P.S. its 9.7v and supposedly 1000 mah
Heisenberg
10,621
I don't know of any commercial products offhand, but you could make your own crude one with the appropriate resistor, DMM, and a stopwatch.
FoBoT
63,084
15
fobot.com
you have to do a load test, it isn't like you can connect something to it and it just measures capacity
sager66
164
New NiMH battery packs can take several charge-discharge cycles to "form" the chemistry . . slow charging is best to "equalize" the individual pack cells. If you know anyone into radio controlled models, they might have the equipment to load test the pack.
TheGizmo
3,627
hmm so theres no easy way to do it, it seems. oh well. i figured i should charge it up max then some sort of device would use the power and measure how many mah based on how long it stayed on. but i guess there is no such device.
arcas
2,155
What kind of battery? If it's a NiMH battery then sager66 is correct. If it's a lithium-ion battery then it could very well be new but just old (li-ion batteries begin deteriorating as soon as they're manufactured whether they're used or not).
You can build a crude capacity testor using a digital multimeter with a serial port and a resistor (sized so that the discharge current is about C/10). I built one a few years ago when I analyzed some NiMH batteries. Measure the voltage across the resistor at 10 second intervals until the battery voltage reaches some pre-determined "discharged" state. Use Ohm's Law to estimate the amount of current transferred during each interval. From that, it's easy to estimate the battery's overall capacity in mAh.
