Battery life
lupi
32,539
260
I've had a kodak dx6490 for about 7 years. About 9 months ago I had to buy a replacement battery. I haven't used it much with the replacement, nor did I keep it on the charge stand since I got it, and after 6 months or so the replacement will no longer hold a charge. Should I start to be worried about the camera internals having gone bad or just toss it to bad luck with the new battery?
corkyg
Elite Member | Peripherals
27,370
239
Bad luck with a bad battery. Was it a 3rd party, or Kodak certitifed?
lupi
32,539
260
nope, was one of those made in china equivalent to batteries.
corkyg
27,370
239
I guess that confirms it - bad luck with bad battery. :)
996GT2
5,212
Most third party replacement batteries are quite bad. If you must buy a third party battery, at least buy one from a reputed maker such as Energizer, Duracell, or Lenmar.
lupi
32,539
260
Originally posted by: Jawo
I have had great luck with the batteries from http://www.sterlingtek.com/ Not only did the 4 batteries I got from them cost less than one OEM battery but they last much longer as well!
thanks for that link. they've got my battery and say they have a 1 year guarantee; from a US supplier so it should be easier to deal with.
