Battery life on backup car battery
TheDingo
552
I have an entertainment system in my car, nothing huge, but it still is enough to put a hurt on my cheap car battery. I've decided to rewire all non-essential power to a second car battery. This battery will be on a isolator so my primary has priority and I won't have to worry if I drain the second by playing around with the stereo when the car is off.
At the very peak, the system will only draw about 550w, so I don't need much in the way of battery power, so now I'm just looking for the smallest battery I can get that will last as long as possible. I've heard I don't want a deep cycle, as they are designed to be totally drained then filled to full and repeated. I need a battery that can survive being drained, but most use will be like a regular car battery. Any ideas? Should I get a small ATV battery and replace it every couple years? A regular car battery?
Thanx
Colt45
19,720
you are planning on hooking the second battery up to your alternator right?
otherwise you'll have to change it more than every couple years.. it will die in a few days..
Evadman
Administrator Emeritus<br>Elite Member
Feb 18, 2001
30,990
More like a few hours. Just how long are you looking for this to last?
And you do want a deep cycle. A regular car battery will kill itself if you totaly drain it a few times ( like 5 or less ) as when it is totaly drained the lead facing on the plates will flake off. A deep cycle can be killed by repededly only half charging. If you take 1/2 of then charge back up to 100, you will be fine. If you totaly kill it, then recharge it to 50%, then kill it then recharge to only 50% again, you can hurt the reserve ( amperage / wattage ) by sulfur buildup on the plates.
Definately go with a Deep Cycle. I have 2 Deep cycle batterys in my truck, both are charged by the alternator, and I never pull more than 30% or so from them before recharge. I have had them for over a year, no probs yet.
Evadman
Feb 18, 2001
30,990
Batterys are baised on reserve capacity or amp hours. If a battery is 1000 amp hours that means you can pull 1 amp for 1000 hours, or 1000 amps for 1 hour before the battry voltage hits 11.8v ( 11.8v is 80% discharged )
volts x amps = watts, so 12.6 x ? = 550 so 550/12.6 = 46.3 amps.
There is your magical number. assume a nice even 50 when you go looking for a battery. ( AKA 1000 A/H would be aprox 20 hours. most car batterys are less than 200-300 A/H's )
TheDingo
552
Thanx for the help Evanman.
And yes Colt 45, is will be on an isolator, on the alternator.
Evadman
Feb 18, 2001
30,990
Make sure the isolator can handle 100% of the output of your alternator or it could overheat. A 100 AMp should be ok for most vehics.
