Battery Life Better With Rooted Phones?
olds
50,119
776
Phone is coming up on two years and even new batteries don't seem to hold a charge for long.
Does rooting a phone so there is no bloatware help battery life?
Contract up in May, may wait till October till the Note 5 comes out.
poofyhairguy
14,612
318
It can help sometimes if you use the Greenify Xposed pluggin, but that is only if you don't have Lollipop.
Dec 4, 2013
187
Xposed is now available on Lollipop 5.0. It won't run on 5.1 yet.
Another Xposed app that helps immensely with battery life is Amped. It basically collates and reduces the number of Google Services wakelocks. You give up some granular location for less wakelocks overall.
Raizinman
2,355
75
meettomy.site
I spoke to the tech about my battery life going down and he suggested a technique what he called cycle the battery. Here is what he told me to do.
1) Turn off phone
2) Plug in charge and charge overnight
3) Turn on phone and use for about an hour
4) Turn off phone and charge to full
5) Turn on phone and use for about an hour
6) Turn off phone and charge to full
7) Turn on phone and start using normally.
After I did the above the phone battery appeared to have a longer charge.
dawheat
3,132
93
Have you tried a factory reset? I know it's a pain but if you plan it out right, it's not that bad to restore your apps and such. This is assuming it's not some rouge app draining your battery after an update (e.g. Facebook Messenger, etc).
Honestly I've never found that things like Greenify and such really helped battery life materially. The right custom ROM can significantly change your battery life, but takes a bit of trial and error.
sweenish
3,656
60
There are ways for it to help.
Xposed has an alpha/beta on 5.0. Is greenify not yet compatible? I haven't been following xposed or greenify for a while.
If you're able to root and flash a custom kernel, you can maybe eek out some extra battery life. Sometimes at the cost of performance because they realize savings by undervolting and/or underclocking.
Is the bloatware actually running? Shady free apps are far worse culprits. Especially the pirated ones.
EDIT: I second trying the battery conditioning as well.
Dulanic
9,966
590
Rooting give you more control over rogue apps so in that aspect it does help. I had a few apps that like to hide their battery usage etc... but with some research I was able to work around it. I have one app that liked to lock GPS for no reason and /w AppOps (Xposed) I just locked it out of using the GPS at all.
openwheel
2,044
17
Not in my experience. I think they are roughly equal.
However, I freeze everything I don't use anyway.
lopri
13,310
687
In my subjective experience it does. It takes some effort at the time of new app installations, however. In my case I use
- Greenify (hibernate unwanted apps)
- Adaway (ad blocker)
- AFWall+ (firewall)
- ROM Toolbox (to shut useless components within apps, such as GCM or autostart)
I am probably a bit on the anti-developer side in this way. I do try to pay for worthy apps whenever possible, hoping they will cancel each other out.
Naer
3,428
181
Just get a 10000mhm external battery. Fits nice in a pocket with a 3ft android cord attached to your phone
