Battery inside the Logitech MX700 Mouse
NesuD
No need to drain it dead before charging. Had mine a few months and it has never had this problem in fact at first the more often i put in the charging cradle the longer the charge would last. took it a couple of charges to hit its max charge.
beatle
5,661
They're regular rechargable AA nimh batteries, not LiIon. I think they're 1600mAH each, IIRC.
WeiWei
183
i was wondering if i could replace those with better, more "juicy" batteries ? like a 2100 mAH..
anybody tried that ?
beatle
5,661
Since they're just regular batteries, they're replaceable with higher capacity nimh batteries. I just wouldn't use nicd or alkaline if you're planning to place it back on its cradle.
thorin
Nickle Metal Hydride (sp?)
Mine were rated @ 1800 or 1850 mAh (I'm using some Sanyo 2100s in it though....since when I got the mouse the Sanyo's were already fully charged).
Thorin
Slash621
189
so wait.. since they arent lith ion dont they need to be drained to 0 before going back to 100?
Derango
3,113
Just use it and don't worry about it :) You can buy the batteries from almost anywhere. Its just a regular battery, nothing special
imported_Phil
9,837
They're NiMh (Nickel Metal Hydride) batteries, 1700mAh. Logitech's website, somewhere, states what types of batteries you should use, up to 1850mAh IIRC.
