Originally posted by: JEDI
Originally posted by: Zenmervolt
That's not how you do a load test...
You load test a battery by applying a load of half the rated CCA for 15 seconds and then checking the lowest voltage level measured during that 15 seconds period against a table of minimum voltage levels for temperature level. A load test at 50 degrees should show a voltage of not less than 9.4 volts (40 degrees would be not less than 9.3 volts). You don't get an amp rating result from a load test, you get a minimum voltage result. The shop that load tested your battery is feeding you BS.
Load Test Description
ZV
i have the printout.
12.8v
270cca
edit:
why does your link say 9.6v for a good battery?
12.8 volts is the resting voltage which is useless for determining battery health. In fact, 12.8 volts is
higher than a battery normally stabilizes at (normal resting voltage is 12.7 volts) which means it's likely that the shop failed to allow the surface charge to dissipate before testing. Batteries will often show higher than normal voltage values for a few hours after being fully charged; this "surface charge" dissipates after sitting for a bit and is not an accurate reading of the battery's true voltage.
The link shows 9.6 volts for a good battery (at 70 degrees Fahrenheit, acceptable voltage is lower at lower temperatures) because there is a voltage drop under load.
CCA is determined by the number of amps a battery can supply for 30 seconds at 0 degrees Fahrenheit without falling below 7.2 volts. For example, a 12 volt battery rated at 550 CCA can supply 550 amps at 0 degrees Fahrenheit for 30 seconds before the voltage falls below 7.2 volts.
Yes, it's possible to back-calculate CCA from a load test using mathematical formulae, but giving just the new CCA number really does not provide a sufficient amount of useful information. Frankly, it seems designed mostly to convince consumers that they need a new battery prematurely. ("Oh, sir, you're
100 amps below your car's CCA spec, you need a new battery
right now!") Auto makers specify a certain CCA rating knowing that even after a year the battery will drop lower than its rated capacity. There is some leeway built into the specification to account for CCA drop as the battery ages, if there wasn't we'd be replacing batteries every year, or even more frequently.
As far as starter draw, a good starter will draw between 130 and 250 amps. For a modestly-sized 4-cylinder you're probably looking at a total amp draw from the starter of 150 amps depending on temperature. Purely theoretically, a
healthy battery with 175 CCA
should be able to start the car even at 0 degrees Fahrenheit if you have all accessories turned off.
ZV
