Battery Backup recommendation
Nov 5, 2001
18,366
Can anyone recommend a battery backup for a Dell PowerEdge 2500 server. Need something that will keep if up and running as long as possible (at least 8 hours). I have already looked into APC, so any recommendations on any other systems?
The HIGHLY TECHNICAL forum is not for purchase advice.
AnandTech Moderator
Mingon
3,012
8 hours - thats going to be expensive. dont suppose you can chain link uninteruptable power supplies.
rjain
1,475
linking them together can cause nasty problems and inefficiencies. I recommend getting a generator to supplement a UPS with a 10 to 15-minute supply. That should be long enough to start up the generator.
RadixTwo
7
Just add some battories to your current UPS. and if there's no room.... put them in a box?
