Battery backup question
machintos
1,652
So I just purchased a belkin 500va emergency battery backup and I plugged it in.
The manual said I needed to charge it for at least 6 hours so I left the thing plugged in all night.
Now when I try to turn it on, it won't even turn on (the lights are dead, no juice to my computer and monitor).
The question is, do I have to do anything else? Or is the product defective?? What do I need to check??
Thanks a lot guys...
racefan
317
It is defective. It should have turned on I beleive.
Make sure the battery is pluged in as if it has a replacable battery it may have shipped with it unpluged;)
machintos
1,652
Yes, I'm sure the battery is in since there's nothing else in the box.
Thanks a lot, I'm gonna go get a refund tomorrow.
Navid
5,053
When I got my UPS, I had to connect the battery as the instructions suggested.
EULA
940
an alternate solution is to simply buy an inverter, and connect some car batteries together...
Navid
5,053
Would that detect loss of power in the AC line and switch to the battery automatically, not allowing the PC to turn off, or are you suggesting it to be left on battery all the time?!
LED
6,127
Did you open the UPS case and remove the tape off the battery?
