batteries. LiThium-ion, NiMH, etc
Adul
44
danny.tangtam.com
looking for clarfication on the energy density difference between NiMH,Lithium-ion, and Lithium Polymer. Which ones is the greatest and by how much.
Howard
47,982
11
I don't know much, but the Li types hold more capacity per volume, and NiMH has a very slight memory effect. Lis do not.
Mday
18,647
lithium polymer has the highest. you will see them used in very small devices, like cellphones and small laptops. with lower prices, it will get into more devices, allowing even lighter laptops. the true benefit of lithium polymer is not the density, it's the size. they can be super thin, like measured in mm, like 7 mm or something. and i dont mean those coin sized batteries either.
i dont know the actual amount.
adul, you know enough to look in google, you pimpin foo. =D
simple search in google "battery types"
http://www.cewindows.net/battery.htm
http://www.thermoanalytics.com/support/publications/batterytypesdoc.html
doesnt answer all your questions, but still...
Adul
44
danny.tangtam.com
doh I was using the wrong search terms:(
Howard
47,982
11
We won't be see Li AA batteries any time soon, though. The standard voltage is 3.6V.
OS
15,581
Single use Li AA batteries have existed for sometime, but they are expensive, cost 6 dollars for a pair.
Adul
44
danny.tangtam.com
i have actually bought a set to run in a gameboy. it did last a lot longer. energizer makes them.
sxr7171
5,079
40
Do you think there could be applications where they sell you a Li AA battery with a dummy battery to work in devices that need 2 AA batteries? Would that combination last longer than an NiMH? Thanks!
MWink
That's an interesting idea. The biggest problem with Li-Ion batteries is charging them IMO. NICD and NIMH batteries can be charged at pretty much any rate for any amount of time (with no real damage except to the battery). If you don't properly charge Li-Ion batteries, I've heard they can explode or catch fire.
Sachmho
1,197
can someone tell me a place online to buy a batter of 2.5-4.0 volt and 350 mah?
OS
15,581
If you're talking about using a single li AA battery to replace two nimhs, it won't work. The li AA batteries still only put out 1.5 volts each and two stacked nimhs give ~3 volts.
IcemanJer
4,307
so Energizer dampen the output voltage of the Li AA battery? I thought it was just mentioned above that the standard voltage for Li is 3.6V?
Jan 9, 2002
5,232
Adul, you post elsewhere besides Off Topic?!? :confused: Check out the July 2002 issue of Maximum PC Magazine- they have the best overview of batteries that I have ever seen that will answer all your questions and more with in-depth pictures. PM me if you or a friend doesn't have that issue and I might sell you mine. :)
daddyo
Li-Ion batteries are notoriously not safe. I'm not saying to be afraid of a battery, but I know a lot of battery manufacturers that choose not to deal with them for safety reasons.
