macattack03
I'm learning and very new to the router and switch environment at the level of cisco with command lines. I'm going to eventually be studying and trying to take my CCNA so learning the stuff I'm asking for help here I hope will help me.
Cisco 2800 series router
Cisco 3560G poe switch 24 port
cable modem > wireless router > cisco router> switch
This is the way I currently have it plugged in I'm working to configure it a different way once I figure some stuff out.
Logging in with SSH thru the Cisco router isn't a problem I finally got that part figured out. However I can't seem to route traffic in thru the switch to pull ip addresses from it as well as logging in with ssh. I'm having to use a console cable everytime I want to do something with it.
Layer 3 switch so I set a interface vlan 58 assigned ip and then setup the ssh commands similar to that of the router
I'm unable to ping from the router to the switch my machine to the switch etc I think its something to do with a routing protocol or making the switch and the router talk
