basic wifi router recommendation?
I'll be getting Time Warner home internet, 50 Mbps shortly and want to buy my own hardware. I'll be running a Motorola SB6121. There will be at most 2 wifi users at a time, and one tv w/streaming video, no cable service. 800 ft^2 apartment. Basic is fine, just need normal security. Any recommendations?
On a budget, get this:
http://www.amazon.com/TP-LINK-Archer...ords=archer+c7
If you don't need/want AC:
http://www.newegg.com/Product/Produc...82E16833320062
or
http://www.newegg.com/Product/Produc...82E16833704144
Really though, if you don't have any special needs, just pick one up from a major manufacturer:
D-Link
Linksys/Cisco
NetGear
TP-Link
Buffalo
TRENDnet
Asus
You can always check the <Router Finder> at www.smallnetbuilder. At the very least get a dual band Wireless N.
kept moving up from crappy routers until I got to this one, and stayed with it.
TP-LINK TL-WDR3600 for $60.
get this one if you're only running a couple devices, generally, and running on ABGN, 2.4 or 5GHz.
i've got multi-torrents on and uploading at +6mbps on google drive constantly while other devices are streaming massive packages on this TP router, while on the moto-surfboard modem, on 25mbps comcast.
These are such excellent routers, I have not found a better BFTB. I am actually running the 4300 which is not much different and about ten bucks more but it runs Gargoyle or DD-WRT all day long.
