Basic SQL query help
KAMAZON
So I've been trying to learn SQL and my associate came up with a interesting question. He wants the total number of instances where Mr, Mrs, Dr, etc. is used in the Northwind DB in MS-SQL. The info is in the dbo.Employees table under the TitleOfCourtesy row. I think I need to do a nested SQL SELECT statement but I'm not sure how to go at it. My failed attempt was this one:
USE Northwind
GO
SELECT COUNT (TitleOfCourtesy)
WHERE TitleOfCourtesy = 'Mr.'
FROM Employees
GO
Any suggestions? Thanks.
Your query will give you the count of people with Mr.
to get the count of each title and the title:
SELECT COUNT (TitleOfCourtesy), TitleOfCourtesy
FROM Employees
Group BY TitleOfCourtesy
TYVM for showing me groupby! I will have to review the different scenarios I can use that. My mistake in thinking through this was for the 2nd part, I wanted to see only the results that are greater than 1. Would anyone be able to tell me how I could do that part? Thanks again.
FROM Employees
HAVING COUNT(TitleOfCourtesy) > 1
FROM Employees
Winnar... 🙂
