Basic requirements for a LAN box are?
MikeMike
45,885
66
.... you guys please answer
i dont know if my comp i am running on right now would be able to pull it off but maybe it can if you could tell me the bar minimums for a LAN box (which is a LAN server correct? if not what r the requirements for that?)
Comp stats right now
p2mmx 233
96meg ram
4gb hd
128stb velocity
cd-rom
burner
floppy
sb pc164
will buy network card
Electric Amish
23,578
Depends on what you are going to use it for.
Most references around here to "LAN Box" are referring to a computer built for gaming. They are generally small and easier to transport to LAN parties.
That system you list would be great for a Network server, depending on what you need to serve.
amish
MikeMike
45,885
66
just serve games that even though they would take forever to load it would probably take the speed lose from a computer actually playing the game and transfer it to tha tcomputer also it could be used as a (simple)app server as in word and other programs right?
please comment on the game server though would it be worth it to even try?
