- Nov 2, 2012
- 214
- 1
- 76
I just purchased an NZXT from Amazon (I assume new version or I will be sending it back) anyways, if I am not mistaken the included fan hub is for PWM correct? I have never utilized PWM on my builds (its been years now) and would like to take advantage of it but it can be a bit overwhelming for a first timer. So essentially I want to be on the lookout for fans with 4 pin connections is that correct? What is the difference b/t 3 and 4 pin fans? Just that a 4 pin makes its pwm essentially? As long as a 4 pin fan is plugged into this hub it will be controlled by way of mobo right?
I feel like this image could be very helpful, but before I go plugging in 10 different wires I'd like to make sure I have it all sorted out. So the "NZXT Fan 1, 2, 3, 4) would all be case fans right, and as long as they are 4 pin I'm good to go with PWM.
The "molex power" is just what I would be connecting to the PSU?
I'm confused about "PWM cable to CPUFAN1" is this cable coming from the hub itself or from somewhere else? Where does it connect?
Which leaves me confused about "CPUFAN" what exactly is this? Where is it coming/going?
Also I will be purchasing an AIO CPU cooler, where will I be running that too?
Sorry for the length its just a bit overwhelming.
