- Jul 10, 2003
- 343
- 0
- 0
i am trying to overclock my 2.4c to 3.0 on my soyo 865pe.
i am trying to do the 5:4 overclock, overclocking just my cpu and leaving everything else the same.
based on my motherboard bios, phoenix.
i have found out how to:
-lock agp/pci at 66/33
-adjust cpu fsb
-adjust all voltages
i cant find out to create the ratio (setting Dram to 333.) but i found something that says "DRAM:CPU"
and one of the options available is "X1.25" which is basically 5:4 from Ram to CPU. i can't seem to get it to do 4:5 from ram to cpu (DRAM:CPU). If i set it to X1.25 or auto, and set my fsb to 250, the DDR jumps to 500 something!!
is there anyway i can just overclock my computer and leave everything the same? i am running latest bios and i am stuck here.
-adjust cpu fsb
