So I started to mess around with learning how to OC
So far only thing I have done is change the CPU Clock ratio (multiplier)to 43.
I had two questions:
1) Right now my vcore is set to auto, how does one know when you need to manually set it? Also what does increasing vcore actually do? Give it more power? I keep reading about people saying vcore and not to go over 1.5 but not sure why.
2) I have the Intel Turbo boost still on default which is enabled. Should I disable all Intel Turbo boost when overclocking and if so why?
