All,
I'm about to complete the upgrading of my house to an 802.11n.
There are a lot of variables within an 802.11n router to consider when purchasing: simultaneous dual-band, 2.4ghz, 5ghz, mimo, 150 Mbps, 300 Mbps... etc etc. My question is this: do I need to match up my wireless n adapters to get the 300 Mbps or to use the 5ghz, for example? Do brand names need to match? Or if I see a router that operates at 5 Ghz and a network adapter that also operates at that frequency, will they automatically work? I want to make sure I get 300 Mbps max since I'll be doing HD streaming over this network.
What's the best way of doing this?
Thanks
Thanks
