- Aug 23, 2006
- 104
- 0
- 76
1. Use. Download 1280x720 video via wireless; output to HDTV via DVI or HDMI; watching streaming HD video content (sometimes via Flash players); Bluray video playing. I'm trying to build my second system, but this time for my parents. Size is one of the biggest factors right now, so Mini-ITX is probably the way to go. My parents currently have a laptop (Sony Vaio @1.8Ghz, GeForce 9300) hooked up to the TV, which they unhappily detach and re-attach every day so they can also use their laptop for other normal purposes.
2. Budget. $500.00.
3. Purchase location. US; Newegg; Microcenter.
4. Brand preference. Intel/AMD.
5. Current parts. Windows 7.
6. Additional: no overclocking, no gaming, hope to build by October 1, 2009.
7. Notes: Size is the biggest concern (assuming that the "use" requirement is met). Because of the very peculiar TV setup, my parent's only can have a Wii/Mac Mini size box on top of their stand, or a very slim (i.e., 4") case that would stand next to the TV stand on the left.
I seriously considered the ASRock ION 330 w/ BD. But after researching the board and chipset, I learned that dual-core atoms (even with nVidia IONs) cannot handle that CPU-intensive process of full screen Flash video or HD Flash video. (See: http://www.anandtech.com/weblog/showpost.aspx?i=602).
So, I started looking around for a different mini-computer, but one with a core 2 duo processor. I saw a couple items here: http://www.thebookpc.com/produ.../68_33/products_id/430, but found them to be quite expensive.
Then I went back to the thought of getting a Mac Mini. My primary concern was with the mixed OS network issues. But, what about clean installing it with Windows? Can I just clean install the Mac Mini with Windows 7 and call it a day?
I'm sure people will ask why I would pay a premium for a Mac, if I was going to install Windows, but I just can't find anything that is this small that packs this much oomph into a tiny footprint. Is there such a thing?
---------edit----------------
So I threw a Micro-ATX system together, that should fit in the allotted space. Could you give me some thoughts on this system?
CASE:
APEX DM-387 (12.75" x 3.9" x 15.75") w/ 275W PSU
http://www.newegg.com/Product/...x?Item=N82E16811154087
$50.00
MOBO:
ZOTAC GF9300 HDMI Micro-ATX (Integrated GeForce 9300 GPU)
http://www.newegg.com/Product/...x?Item=N82E16813500019
$100.00 ($80.00 after rebate)
CPU:
Intel E7400 @ 2.8 GHz
http://www.newegg.com/Product/...x?Item=N82E16819115206
$80.00 (at Microcenter)
RAM:
G.SKILL (2 x 2GB) DDR2 800 240-Pin
http://www.newegg.com/Product/...x?Item=N82E16820231122
$52.00
HDD:
Western Digital 640GB Black
http://www.newegg.com/Product/...x?Item=N82E16822136319
$75.00
ODD:
LITE-ON 4x BD-ROM SATA
http://www.newegg.com/Product/...x?Item=N82E16827106326
$68.00
Other:
Molex to SATA adapter (only one SATA power on PSU)
http://www.newegg.com/Product/...x?Item=N82E16812201002
$4.00
$409.00 total.
2. Budget. $500.00.
CASE:
$50.00
MOBO:
CPU:
RAM:
$52.00
HDD:
$75.00
ODD:
$68.00
Other:
$4.00
$409.00 total.
