Too bad about the BootBase.
Inspite of this small set back, you're still ok. Go ahead and upgrade to the latest
Netgear firmware. Everything in the Zyxel firmware eventually makes it into the Netgear firmware. Go with version 3.22 as 3.24 appears to have some flakey problems with it.
One bit of advice, if you choose to upgrade your firmware by sending it via ftp as "ras" make sure you ftp in the "rom-0" file also. This will effectively reset everything back to default settings within the router and you will have to set it back up again. You may wonder, "Why do that?" The reason is because doing this completes the firmware upgrade. If you look through the forums
here you will find where some have had strange problems after flashing their router's firmware Some of us believe this is due to not sending the "rom-0" file after flashing the firmware. The point is to follow the instructions in the Netgear manual as there is a reason for doing it the way they say to.
