basic calculus help
Status
Not open for further replies.
Pantlegz
it's pretty basic but I don't really know where to start with it.
y'=((e^αe)^-2&#945😉
I know derivatives with exponents would be something like
-2((e^αe)^-2&#945😉)(-2&#945😉'
-2(α((e^αe)^2&#945😉)(αe)')(-2)
-2(α((e^αe)^2&#945😉)(1))(-2)
But it doesn't look right, I'm sure I really messed something up with chain rule, we're also working with product rule, which also isn't applied. So I'm sure that's nowhere near correct.
What is the question? Are you trying to find out what y is? Is y a function of a? Also is that supposed to be written that way or do you mean y'=e^(ae^(-2a))? The version you have seems to be equal to e^(-2(a^2)e)
I see your trying to do the derivative so maybe thats what you are asking. If its written correctly now and y is a function of a, the answer is (-4ea)((e^ae)^-2a).
yea I'm trying to find the detivative for the problem, the way it's written in the book is:
y=e^αe^-2α. which isn't turning on the way I want it to so I'll type it out, it's e to the ae power to the -2a power. If that makes sense.
So I simplified it the way my professor told me to which is what I have above. If that's there you got (-4ea)((e^ae)^-2a), would you mind breaking it down so I can see where I'm off. Thanks!
Here's my take:
Why on earth do they teach calculus without story problems?
No one can relate to a bunch of equations...
So, like Wizlem, I'm slightly confused by your notation, since y(a)=((e^αe)^-2&#945😉 simplifies to e^(-2a^2e) but I honestly feel that the desired function is y(a) = e^(ae^(-2a)).
So I'll solve for that problem.
Let f(a) = e^(-2a) then, f'(a) = -2e^(-2a)
y(a) = e^(af(a)) => y'(a) = e^(af(a))*d/da(af(a))
and d/da(a*f(a)) = f(a) + af'(a)
Combining:
y'(a) = e^(ae^(-2a))[e^(-2a) -2ae^(-2a)]
Simplifying:
y'(a) = e^(a(e^(-2a) - 2)[1-2a]
To give our friend edro a story:
Billy has a continuous population that grows (approximately) exponentially in time (denoted a) The growth constant itself decays exponentially with time with constant -2. Billy really wants to know the instantaneous rate of growth at any given time, give him the necessary function of a.
Status
