Well this one is straight out of basic air cooling a case 101 and I'm pretty sure I know the answer already I just want some verification. I have an Antec 300 case with the following airflow:
2 Cooler Master blue LED fans on the front intake (approx 40 cfm apiece)
2 Cooler Master fans on the H212+ (push/pull)
2 Antec Trio fans on the exhaust (approx 80 cfm apiece if I'm looking at the correct specs, these are the ones that come with the case,one back & one top)
So if I remember my airflow math correctly I have a negative airflow of approx -80 cfm. Will I get better cooling results by moving to more of a neutral airflow by swapping out the two intake fans to two intake fans that have the same cfm as the exhaust? Specifically I'm thinking of going for a pair of these Antec Tricools (http://www.microcenter.com/single_product_results.phtml?product_id=0253110). Yeah I know basic question but at least it should be easy.
